Hi, I use Material Studio 2018. I want to generate CeO2(111) surface with geometry optimization in CASTEP. I selected GGA-PBE and LDA+U (U=6 eV for Ce f orbital). Also, I must select 'spin-polarized' for Hubbard parameter. After SCF cycles (9999 cycles), electronic minimisation did not converge. How can I solve this problem? Does anyone have any idea? Thanks
Sincerely
there are several potential issues with this calculation:
(1) please check that there are no dangling bonds and that the surface is charge neutral (e.g. that the unit cell you are using contains a multiple of CeO2).
(2) try to make sure that the surface is symmetric: there should be no net dipole moment across the surface by terminating one side only with oxygen and the other with cerium. If you must use a non-symmetric surface, please make sure that there is sufficient vacuum (>10 Angstrom) and use the dipole correction to avoid electrostatic interactions between periodic images of the surface.
(3) you might want to lower the density mixing parameters for charge and spin on the Electronic Options | SCF dialog.
All the best,
Felix
