I am running some CASTEP free energy calculations and would like some support on assessing the output.
From my calculations on a small molecule I get a negative phonon frequency, which normally means the structure is not on a minimum or something is wrong with the calculations…
+ Vibrational Frequencies +
+ Performing frequency calculation at 1 wavevector (q-pt ) +
+ q-pt= 1 ( 0.000000 0.000000 0.000000) 1.0000000000 +
+ Acoustic sum rule correction < 9.874013 cm-1 applied +
+ N Frequency irrep. ir intensity active raman active +
+ (cm-1) ((D/A)**2/amu) +
+ 1 -8.683585 a 0.0000000 N Y +
+ 2 -0.058355 b 0.0000000 N N +
+ 3 -0.047438 c 0.0000000 N N +
+ 4 -0.033043 d 0.0026330 N N +
Can someone explain how the sum rule is applied (eg to all modes or just the 3 translations?) and suggest solutions to having a negative frequency?
