hello. I've installed material studio 5.0 on my laptop which its os is w 7 ultimate 32bit.
I've been following "Predicting the lattice parameters of AlAs from first principles"
through the help of MS, when I started to run the job I recieved this message:
The job has failed.
Download any results generated so for?
(Results files will be permanently remove from server)
This time I figured it out I think it was due to the license.
And I installed the license package and run the server. but I steel has the same problem.
| Time | Module | Type | Message Text |
| 2011/02/12@09:42:05 | Diagnostics | INFO | Log file created |
| 2011/02/12@09:43:53 | [RXYKF] - Al CASTEP GeomOpt | ERROR | Licensing Error ! |
| 2011/02/12@09:43:57 | [RXYKF] - Al CASTEP GeomOpt | ERROR | Error on Job Complete. Failed to import document from C:\\Users\\Reza\\Documents\\Materials Studio Projects\\AlAs_lattice Files\\Documents\\Al CASTEP GeomOpt\\Al.xsd. - binary file with castep results not present. |
| 2011/02/12@09:43:57 | [RXYKF] - Al CASTEP GeomOpt | ERROR | Files not removed from server due to previous errors. |
| 2011/02/12@09:43:57 | [RXYKF] - Al CASTEP GeomOpt | WARN | As instructed, files have been left on remote server, these may need to be manually archived. |
THANK YOU.
