Dear MS users,
We are facing diffuculty in starting the MS Gateway. We are using MS5.5 on OpenSuse 12.3 (64 bit) server.
Following are the outputs of gwstart and gwtest and gwinfo.
rioja MS55/UNIX# /opt/apps/MS55/etc/Gateway/gwstart
Server configuration...
ONETEP
PowderQPA
Gaussian
ConQuest
Morphology
Sorption
Discover
CSDMotifSearch
AC
MatServer
Conformers
Polymorph
Mesocite
DPD
Blends
AdsorptionLocator
PowderRefinement
DFTBpara
VAMP
QMERA
DMol3
GULP
MesoDyn
AmorphousCellConstruct
FastDesc
QSARModels
Motif
Scripting
Kinetix
PowderIndexing
CASTEP
Equilibria
PowderSolve
DFTB
Forcite
Server configuration complete
Starting gateway at rioja:18888
/opt/apps/MS55/etc/Gateway/root_default/httpd/bin/apachectl start: httpd started
Gateway start failed - process 5202 is not running.
rioja MS55/UNIX# /opt/apps/MS55/etc/Gateway/gwtest
Testing gateway installation for script u/dsd_test.pl
Running GET for url http://rioja:18888/dsd/commands/u/dsd_test.pl
Error: 500 Can't connect to rioja:18888 (connect: Connection refused)
Now try a POST...
Retesting url http://rioja:18888/dsd/commands/u/dsd_test.pl
rioja MS55/UNIX# /opt/apps/MS55/etc/Gateway/gwinfo
Getting current gateway parameter information...
gw_archivejobinfo = no
gw_authentication = minimum
gw_configroot = /opt/apps/MS55/etc/Gateway/configurations/default
gw_configroot_escaped = /opt/apps/MS55/etc/Gateway/configurations/default
gw_configuserid = root
gw_corespercpu = auto
gw_cpu = Intel(R) Xeon(R) CPU E5620 @ 2.40GHz 2393 MHz
gw_cpuclock = 2393 MHz
gw_cpucorestotal = 16
gw_cputype = Intel(R) Xeon(R) CPU E5620 @ 2.40GHz
gw_docroot = /opt/apps/MS55/etc/Gateway/root_default
gw_gatewayname = rioja_18888
gw_hostname = rioja
gw_installedmemory = 16064 MB
gw_ipaddress = 172.28.10.3
gw_jobpriority = low
gw_jobsdocroot = /opt/apps/MS55/etc/Gateway/root_default
gw_jobspath = /opt/apps/MS55/etc/Gateway
gw_jobspath_escaped = /opt/apps/MS55/etc/Gateway
gw_licensewaitoverride = undefined
gw_mountcomment = #
gw_mpi = yes
gw_mpiavailable = yes
gw_mpicommand = /opt/hpmpi/bin/mpirun -e MPI_REMSH=/usr/bin/ssh -prot -f APPFILE
gw_mpiversion = 2.03.01.00
gw_msrootpath = /opt/apps/MS55
gw_osname = linux
gw_osversion = 3.7.10-1.16-desktop
gw_path = /opt/apps/MS55/etc/Gateway
gw_path_escaped = /opt/apps/MS55/etc/Gateway
gw_perlexe = /opt/apps/MS55/bin/perl
gw_perlplatform = x86_64-linux-thread-multi
gw_perlversion = 5.8.9
gw_pollingfrequency = 5000
gw_port = 18888
gw_queuingsystem = [none]
gw_ram = 16064 MB
gw_revision = 2010.07.30
gw_scriptspath = /opt/apps/MS55/etc/Gateway/root_default/dsd/servers
gw_tmpdir = /opt/apps/MS55/etc/Gateway/root_default/CGItmpfiles
gw_transport = ssloff
gw_type = cluster
gw_unixcomment = #
gw_versionmajor = 5
gw_versionminor = 5
gw_win32comment =
...Information complete
We could not understand the origin of the problem. Please respond so that we can
start running MS.
Chandan
National Chemical Laboratory
India
