cannot script k-Point parameters
Dear MS Users,
i want to test covergence of a system in CASTEP with the number of k-Points.
I can well run the calculations separately and select different k-point separations, but when I tried doing something like
eval {
                \\\$dat = \\\$castep->Energy->Run(\\\$doc, Settings(Quality => "Medium", TheoryLevel => "GGA", SpinPolarized => "Yes", UseInsulatorDerivation => "Yes", UseCustomEnergyCutoff => "Yes", EnergyCutoff => "800", KPointDerivation => "Separation", KPointSeparation => 1.0/(\\\$size*\\\$q)) );
in a script i always get Server process has died unexpectedly in CASTEP.Energy (function/property "Run")
Using the same structure document.
has anyone noticed this before?
is there a way to work around this?
Also there are Options ParameterABC to set the k-Point grid parameter but KPointDerivation does only allow "Quality, Separation, Gamma"; not "Custom" as in the k-points tab of the castep dialog. Why is this?
Why does CASTEP use only the gamma point by default for insulators?
thanks in advance!
Martin
