Bonds, Angles and Torsions from periodic structure
Hi all,
I have a "small" problem. I need to print out bonds, angles and torsions from periodic structure, but unfortunately I do not know how to do it.
Originally, I need to create so called mmol file given as follows:
# FAU.xsd - zeolite structure supercell
#  Number of atoms
        4992
#         x            y          z            Ar           Q         sig        eps       FF      no
Si     23.225    3.071    0.890    28.0900   0.8646   3.2857   0.2100   Si_z     1
#  Number of bonds
        6144
     1     5   1.61500   2931.00                     #  Si_z-O_z
     1    78  1.61500   2931.00                     #  Si_z-O_z
     *                         *** Up to this point, I know how to print it, but further on is a bit mistery! ***
#  Number of angles
       12288
     5      1    78    109.4700      418.00     #  O_z-Si_z-O_z
#  Number of torsions
       18432
   78       1     5     2    180.000    4.180   3     #O_z-Si_z-O_z-Si_z
   387     1     5     2    180.000    4.180   3     #O_z-Si_z-O_z-Si_z
I know how to do it manually for each structure under Linux enviroment, but I would like to generate it for hundrets of structures from Materials Studio directly.
The problem appear earlier (https://community.accelrys.com/thread/5054), but for one part of the solution user need to Find Patterns tool to automatically create all of the angle monitors. Unfortunatelly, I do not know how to do it.
So, can someone help me with this? Basicly, it would be more appreciate to have a solution in script form, which is then much easier to apply for large number of files.
Thank you for your time!
Best regards,
Bojan
