"Big hole" in the solution after running MD
Dear All,
I'm running a MD on a solid-solution-solid sandwich-like system to see the adsorption of ions in solution to the surface of the solid phase. After running the simultion, some water molecules penetrated into the solid, ions in the solution were adsorbed on the surface. But there was a big less concondensed area in the middle of the solution, which looked like a "big hole". In the concentration profile for oxygen in water molecules, water molecules showed big peaks at the near surface area, and there was a big dent  in the middle plane area of the solution, and this phenomenon became more evident with increaing concentration of the solution. However, this "big hole" was not alway located at the same position, if I compare different runs for the system with same solution concentration. This brought a big problem when I tried to calculate the interaction energy between ions and the solid phase, it looked like the "big hole" prevent the free diffusion of ions, the interaction energy showed big difference between different runs. I ran NVT for the dynamic. I also tried to run NPT first to equilibrate the system, then use NVT to get the dynamic date, but there was still a big hole in the solution.
Does any one have a solution for this? Thank you
Regards,
Jingjing
Answers 7
JD
JD 2014-05-02
Hi Jingjing,
Yes this has happened to me too. The problem is that there is more space between the solids than is needed by the liquid, so a vacuum bubble is formed. There are several ways you can deal with this:
  1. Move the layers 2-3 Angstrom closer together after using the Layer Builder
  2. Instead of using the Layer Build, use the Amorphous Cell packing task with an isosurface to pack the empty space at the correct liquid density (see tutorial)
  3. Run NPT dynamics with the Souza-Martins barostat to allow the cell lengths to equilibrate independently (may result in some distortion of the cell). You can even use a higher pressure in the direction normal the surfaces in order to speed things up.
Also I would note that since it is a periodic system, it is not necessary to include two solid layers, unless there is something different about the each solid layer.
Best regards,
Jason
JB
JB 2014-05-02
Hi Jason
Thank you. But I don't understand your first solution. When I used Layer Build to build the system, I left no distance between two layers. I mean the thickness of vacuum between two layers was 0. But there was still gap between two layers to prevent overlap. You said move the layers closer, you meant less vaccum or less gap?
Regards,
Jingjing
JB
JB 2014-05-02
Hi Jason
Also, for the second suggestion about using Amorphous Cell, I read some where that "confined layer" + "layer build" was the most recommended method to build liquid-solid system as the system is easier to equilibriate. For a liquid-solid system built with AC, is there any equilibrium issue?
Thank you.
Regards,
Jingjing
JD
JD 2014-05-05
Select the atoms in the layer and move them with the buttons on the toolbar
JD
JD 2014-05-05
Actually it is the other way around. Building with Amorphous Cell by packing into an isosurface is a more refined way of doing it.
JB
JB 2014-05-05
Hi Jason
Thank you.
I have another question about your last comment. The solid layers are same, I put two layers because it has different (0 0 1) and (0 0 -1) surfaces, anions and cations would adsorb to different surfaces. In this case, it's still OK to just put one solid layer? And in the trajectory of solid-liquid system, we can see anions go to the solid-liquid interface, cations go to the other side of liquid phase (actually it's also a solid liquid interface). But it's not as straight forward as the two solid layers system to see adsorption on two surfaces, because for solid-liquid-solid system, we can show two layers of solid in the concentration profiles and have two solid-liquid interfaces adsorptions. Is there a better way to show the adsorption in the all-element concentration profiles? Thank you.
Regards,
Jingjing
JD
JD 2014-05-07
Jingjing Bu wrote:
Hi Jason
Thank you.
Only if (0 0 1) and (0 0 -1) are the same.
Hmm, maybe if you shifted everything down a bit in the unit cell (and change lattice display style to "in-cell")... but I haven't tried.
