Band structure calculations within CASTEP
I am running a large set of gas phase molecules via the molecule-in-a-box paradigm using CASTEP across several clusters. Each structure can result in about 2-5GB of data generated between the .castep_bin and .cst_esp files from an energy+band structure calculation. One of the clusters we use runs Academic CASTEP, which means I do everything manually there and cannot rely on MaterialScript API to streamline the analysis process.
Since there will be a massive amount of data (100s of GBs) that I do not want to transfer back to Materials Studio for analysis, is there a way I can generate the band structure plot and derive the value of the band gap?
Thanks,
Stephen Monaco
Answers 2
SM
SM 2014-06-29
After further investigation, it seems I can generate band structure plots within Materials Studio without the .castep_bin or .cst_esp files. This makes the real result size manageable to the point where I can retrieve them and analyze locally. So it appears as if this problem is solved.
However, another problem. How does one retrieve the HOMO and LUMO energy levels from a CASTEP calculation?
SM
SM 2014-06-29
If it is necessary to write a script or program, I can do that if given enough information about how to retrieve the band information. I'm not clear if the .castep result file of a band gap calculation is sufficient.
