Dear MS Community,
I’m working with a molecule whose initial torsion angle is 2.2°. However, when I use the Amorphous Cell module to pack multiple copies of this molecule into a periodic cell, that torsion angle changes. I confirmed this by extracting a single molecule from the .xtd file, and measuring its dihedral. I’ve tried various options, but can’t preserve the 2.2° torsion during packing or the subsequent geometry optimization. My goal is to lock this torsion angle in both the Amorphous Cell construction and the geometry optimization step, yet allow it to evolve freely during the Forcite molecular dynamics run. Could anyone advise how to enforce a fixed torsion angle during packing and optimization in Materials Studio?
This may be due to optimization of the molecule in the Amorphous cell construction. Try without geometry optimization option.
Thanks Hakkim for your suggestions. I have tried various options in the Amorphous cell module. Below is an attached screenshot which shows all the possible options available. I have tried many combinations but none of them seems to be working. Maybe @CM and @TM can comment more.
For our purposes we must divide the procedure into two stages; Amorphous Cell without geometry optimization and Forcite to do geometry optimization.
Amorphous Cell tasks, in which the "Optimize geometry" is unchecked, change the torsion angles when the Torsion objects are assigned to molecules (not polymers [*1]). Once you achieve the desired torsions for molecules, delete the Torsion objects, and use the molecules in Amorphous Cell without "Optimize geometry".
In Forcite Task: Geometry Optimization, the only way is to apply the restraints to the torsion objects. The harmonic-type potential energy is applied to the torsion angles to control the angles to be constant. Since the restraint potential energy must far exceed the torsion angel potential energy determined by the forcefield, we can start 5000 kcal/mol/radian^2 as the force constant. The following online help will be helpful,
Visualizer Tools > Restraints > Imposing restraints
[*1] If the molecule is generated by Homopolymer/Block Copolymer/Random Copolymer dialogs, the Linear Chain class is assigned to the molecule automatically. The torsions in backbone of the molecules having the Linear Chain class are updated with the default settings in Amorphous Cell. If such situation is not desired, please uncheck the "Calculate automatically" box in the Amorphous Cell Options dialog to keep the torsion angles to be initial values.
Why do you want to keep the torsion angle at 2.2°?
Do you want to allow all other torsion angles to vary?
As Toshiki said: in the backbone (if there is one) torsions are adjusted to give a meaningful torsion distribution and to properly fit a polymer into the cell.
For torsion in site chains this has to be explicitly checked.
Could you please zip the .xsd file to the molecule and add it to the post.
Which forcefield are you using?
Hi, thanks for your replies. I am using the CompassIII forcefield. I am attaching .xsd file of the molecule. I want the molecule to be rigid throughout the AC construction and GeomOpt, and let it change its geometry only during Dynamics task.
Why do you want to fix that torsion during the build stage?
Could you please a screenshot with the torsion measured to see which torsion you want to fix?
I am studying the aggregation of the drug molecule during crystallization. Hence, the torsion angle is the parameter that can be tracked during the MD simulation and can be used to predict the polymorphic form. Attached below is the screenshot with the torsion angle that I want to fix.
