Amorphous Cell Calculation has Software problem
Hi all,
Trying to put a few tens of a polymer in a box (amorphous cell), I fall over the error here below. It has apparently nothing to do with my molecular system - but is related to the compiled program. How to solve it?
Thanks for the help!
Stefan
Module                          : Amorphous Cell
Version                         : 2025
Build date                      : Oct  4 2024
Host                            : W-530217
Operating system                : Windows
Task started                    : Thu Jul  2 13:45:43 2026
Random number seed              : 1032431287
---- Amorphous Cell calculation ----
Task                            : Construction
Density                         : 0.800 g/cc
Number of frames                : 1
Optimize geometry               : yes
Loading steps                   : 1000
Check ring spearing             : yes
Restrain rings                  : no
Check close contacts            : no
Check energies                  : yes
Bias temperature                : 298.000 K
Look ahead                      : 1
Framework charge                : 0.000 e per cell
| Component        | Charge      | Loading     |
|_______________________________________________
| 1Pol_40units_Opt | -2.008e-005 |          35 |
---- Construction task parameters ----
Ramp density                    : no
---- Energy parameters ----
Forcefield                      : Universal
Charges                         : Use current
Electrostatic terms:
 Summation method              : Ewald
 Accuracy                      : 0.001 kcal/mol
 Buffer width                  : 0.5 A
van der Waals terms:
 Summation method              : Atom based
 Truncation method             : Cubic spline
 Cutoff distance               : 12.5 A
 Spline width                  : 1 A
---- Configurational Bias Monte Carlo method parameters ----
| Component        | Head bias   | Torsion     | Torsion     |
|                  | steps       | twisters    | bias steps  |
|_____________________________________________________________
| 1Pol_40units_Opt |          10 |          57 |          10 |
Task terminated                 : Thu Jul  2 13:49:45 2026
Total CPU time used             : 3:56 minutes
ERROR: This document has no URL
Termination status              : Error
