Hello.
I sometimes wonder when using Dynamics with DFTB + and Forcite.
There are many different Thermostats available in Dynamics (Velocity Scale, Nose, Andersen, Berendsen, NHL ,,,), but I have no idea what their usage characteristics are.
The principle part is in MaterialsStudioOnlineHelp, so it is about the other parts.
For example, this Thermostat is suitable for such materials (polymers, organic molecules, indefinite periods, etc.), how they are used in several stages of relaxation, and so on.
If anyone is familiar with Thermostat, would you please teach me?
***Append***
In my opinion, although "Thermostat" is a very important element in classical molecular dynamics calculations, I feel that there is little literature written about it.
So, if you share your knowledge and rules of thumb about this, it can be very useful information.
* For example, I think that it corresponds to something like "Which functional should I choose?" that is referred to when selecting a functional in quantum mechanics calculation.
Such literature is rarely found in classical molecular dynamics calculations....
See the help page Theory > Dynamics theory > Temperature for a detailed description of how each thermostat works
This is one important property of a thermostat: does it correctly sample the canonical distribution? i.e. does the states that it generates have the correct relative probability (according to statistical mechanics) for a system at constant temperature? If you want to correctly calculate thermodynamic average quantities, this is important. Some thermostats (Nose/NHL) have this property, the others do not.
Another important property of a thermostat is how quickly it operates: does it rapidly correct the kinetic energy of the system? Velocity Scale is good for this.
So a good rule of thumb is this: use Velocity Scale for the equilibration phase of the calculation, and NHL for the production phase.
Hi Neil SPENLEY, and all.
Thanks for the detailed advice.
There are some additional confirmations and questions.
1. I understand that the general order of use of Thermostat is as follows, but is it correct?
* Velocity Scale or Anderson (To Coarse? scaling) -> ( If I want to heat... Berendsen[1] -> ) Nose or NHL (To consider thermodynamics)[1]
[1] Set "Initial velocities equal Current" like this.
2. What is "production phase"?. Is this recognition correct?
* Molecular dynamics calculations with more steps than equilibration, performed to further stabilize the equilibrated system.
The analysis is performed by the structure from this step.
3. Could you tell me about the differences between these phases?
* "Equilibration phase", "Anneal phase", "Production phase".
If anyone who has seen this topic has any idea of these questions, would you please let me know?
Thanks a lot.
Kuroki
