Dear all,
I did opyimize Ni13 cluster using the following input.
# Task parameters
Calculate optimize
Opt_energy_convergence 1.0000e-005
Opt_gradient_convergence 2.0000e-003 A
Opt_displacement_convergence 5.0000e-003 A
Opt_iterations 1000
Opt_max_displacement 0.3000 A
Opt_restart on
Initial_hessian improved
Symmetry Auto
Max_memory 2048
# Electronic parameters
Spin_polarization unrestricted
Charge 0
Basis dnp
basis_version basfile_v4.4
Pseudopotential none
Functional rpbe
Aux_density octupole
Integration_grid medium
Occupation thermal 0.01
Cutoff_Global 4.5000 angstrom
Scf_density_convergence 1.0000e-005
Scf_charge_mixing 0.1000
Scf_spin_mixing 0.1000
Scf_iterations 1000
Scf_diis 16 pulay
Use_DIIS_Restart off
# Print options
Print eigval_last_it
# Calculated properties
Frequency_analysis on
And the structure looks like the one that i have attached here.
Do you think whatever i am doing is making sense? The only thing i am worried about is the smearing value i am using. Please provide feedback to me, what are the things i should focus more?
Also, I want to know about symmetry information. Since, i just made the structure and ran it. Symmetry off calculation was done during the first run ( without freq analysis), and for the second run i turn on the freq to calcualte vibrational freq. Is this a good approach. I am trying to look adsorption of gas on this molecule.
Thank you.
# Task parameters
Calculate optimize
Opt_iterations 1000
Opt_restart on
Symmetry Auto
Max_memory 2048
Charge 0
Basis dnp
Functional rpbe
Scf_iterations 1000
Scf_diis 16 pulay
# Print options
Thank you.
