Hi:
I am able to superimpose two or more structures based on sequence homology. I wanted to know how the sequence alignment is translated into superimposed structure. More precisely, are the backbone of sequence that are identical or homologous force to stay together? Are the orientation of amino acid side chain taken into account during this process?
Thank you for your input,
Stephanie
Discovery Studio uses a least median of squares approach for superposing. The residues used are those that are aligned in the defined reference sequence alignment. The atoms considered in each residue can be C-alpha, backbone or all matching atoms (it is your choice). If you are using DS 3.0, in the Superimpose Proteins toolpanel under Advanced Settings there is a 'Atoms to use' field that has options: C-Alpha, Main-chain and Matching names.
