Considerations for running
The protocol is not supported on Windows.
What does it mean? Does it mean that it can not run on WINDOWS OS?
But it can be run by using CPU, it should be run in WIN OS.
When running on a GPU platform, increasing the Number of Cores per Simulation from 1 to 2, 4, or 8 will typically result in better performance.
Does the Cores is the NVIDIA CUDA® Cores, if the NVIDIA QUADRO K620 has 384 cores, I want to use the GPU completely, so, Numbers of simulations set to 3, should I set the Number of Cores per Simulation to 128 (384/3)?
The DOMDEC GPU platform only supports a single GPU.
If I use three GPUs , how to set the parameter of Platform and Grid Options?
