My system is Windows 7, and my firewall off. Everything I will run a molecule:
The file 'C:/Program Files (x86)/Accelrys/SES/web/jobs/Jonas/{084C60DE-68C8-42AA-8092-5DAB486BF8CF}/Input/Molecule.dsv' could not be opened for reading.
at (eval 11) line 43
main::onInitialize
Error calling function
Error during call to function pilot::setup::scriptingOnInitialize
PerlScript::HandleError: Pipeline Pilot exception caught
PerlScript::Call: Pipeline Pilot exception caught
CComponentPerlPlugin::onInitialize: Pipeline Pilot exception caught
-> Perl (on Server) - error during Initialization phase
CProtocolBaseImpl::GetNextStartNodeForNewData: Pipeline Pilot exception caught
CProtocolBaseImpl::SetUpComponentStack: Pipeline Pilot exception caught
CProtocolRtc::onProcess: Pipeline Pilot exception caught
CProtocol::onProcess: Pipeline Pilot exception caught
-> Subprotocol - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception caught
-> DS Molecule Reader - error during Data Record Processing phase
-> DS Typed Structure Reader - error during Data Record Processing phase
vcRunComponent::onProcess: Pipeline Pilot exception caught
vcRunComponent::processData: Pipeline Pilot exception caught
CShortcutComponent::onProcess: Pipeline Pilot exception caught
-> Shortcut Component - error during Data Record Processing phase
Protocol Run DS Protocol, user Jonas: Pipeline Pilot exception caught
Protocol Run DS Protocol, user Jonas: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 7.5.2.500
Server OS: Windows 6.1 Workstation
I solved this problem with the help of technical support (Katalin Nadassy):
Could I please ask you to check the permissions on the C:/Program Files (x86)/Accelrys/SES/web/jobs/ directory on your machine please? The problem you run into could be related if this directory has permission settings so that only the administrator has write privileges to this area.
You create a file. bat to assign permission to users. The command of this file would be: cacls C:\\Program Files (x86)\\Accelrys\\SES\\web\\jobs /T /E /G Usu rios:F
OBS.: Usu rios= Grupo de usuário que será dado permissão, como usuários tem acento, o Windows interpreta o usuário como usu rios.Se você utilizar um usuário sem acento não terá este problema.
