problem installing client software for the DS2017-R2
I successfully installed the DS2017R2 server in my Linux computer running Redhat 6.8. Unfortunately, when I tried to install the DS2017R2Client.bin in the same Linux computer I am getting the following message.
"No Java Runtime Environment(JRE) was found on this system. The JRE may not have successfully extracted if there is insufficient temporary disk space. Before installing, ensure that there is sufficient temporary disk space, or rerun the installer using the -is"
The BIOVIA support team was aware of this problem but could not find any solution so far. I would appreciate if anyone had similar problem and found a solution and share the same.
Please note that I encountered the same issue even with the DS2017 first version. DS2016 was running successfully in the same Linux computer.
