Dear all,
I'm writing a perl script for the DS client that calculates the RMDS between different poses of a ligand.
In practices, starting from a set of 15 poses of the ligand loaded in a Molecule Window, the script should be able to calculate the rmsd between the first and the each of the other poses.
However, when I run the script, the DS client crashes and makes the gnome desktop environment block. Does anyone have an idea about the source of the problem?
Thanks in advance,
Davide
----------------------------------SCRIPT-----------------------------------------------------------------
#!/usr/bin/perl -w
# NOTE: This script MUST be run from the DS client
use strict;
use MdmDiscoveryScript;
use SbdDiscoveryScript;
my \\\$document = DiscoveryScript::LastActiveDocument(MdmModelType);
my \\\$molecules = \\\$document->Molecules();
Usage(
"This example requires an open Molecule Window containing docked protein poses"
) unless ( \\\$molecules->Count > 0 );
my \\\$master = \\\$molecules->[0];
for (my \\\$id = 0; \\\$id < 15; ++\\\$id)
my \\\$molecule = \\\$molecules->Item(\\\$id);
my \\\$mol1 = \\\$master;
my \\\$mol2 = \\\$molecule;
my \\\$rmsdAll = \\\$document->CalculateHeavyAtomRmsd( \\\$mol1, \\\$mol2 );
print "\\\$mol1 \\\$mol2 \\\$rmsdAll\\n";
-------------------------END OF THE SCRIPT---------------------------------------------------------
