My protein didn't move during simulation
Hi, All:
I used the CHARMm force field, and set steps at 100000, time step 0.0005. and I've tried both dynamics integrator.
But after the simulation, the protein is just fluctuating about the starting structure.
I've also performed simulation using CHARMM and it does fluctuate a lot.
Anybody has idea or suggestion on this?
Maybe I need to extend the simulation time?
and what is the unit for the time step?
Thank you very much in advance.
Chuanyin
Answers 1
HP
HP 2009-07-31
From your question my guess is that you are using one of the Discovery Studio (DS) Simulations protocols, for example, Standard Dynamics Cascade. You have changed the default time step from 0.001 to 0.0005 (perhaps a sign that you had stability problems in earlier tests?), and have tried different integrators (Advanced Menue). Okay. Of course, oscillation with no "net" movement could be taken as a sign that the system has reached an equilibrium. But, you're right to be skeptical. In Discovery Studio you can plot potential energy, and other parameters versus time to see just how much variation is occurring. There are also DS protocols that allow measurement of the molecular rmsd or various radial distribution functions (for two groups of selected atoms). Finally, using Analyze Trajectory you can add distance and other monitored values to the data table so that these can be plotted over all frames. These features are all helpful to assess the movement of your simulation.
Without seeing the movement you described it is difficult for me to guess the cause; the oscillation might instead be due to harmonic constraints or other constraints that are trapping your molecule in a specific (high energy) state -- but you did not mention constraints so I'll assume you have none.
There are two options you could explore using Discovery Studio if you want to force some larger scale movement. The first is to heat the molecule above the default of 300 deg K by modifying the temperature parameter in the Heating component (and in subsequent components).
The other option (in DS) is to apply distance or other restraints. After creating the restraint(s) you can modify the restraint objects with distances you choose (the default distance is the current distance of the atoms for which the constraint is defined). This should be done with caution as it is easy to force non-physically realistic deformations if the forces are too strong.
If you need further help with this feel please contact Accelrys Support at support@accelrys.com
