Molecular dynamics
I need to calculate binding energy of a complex (drug-protein) with standard deviation using MM-GBSA or MM-PBSA.
I have already my complex
Starting from my complex, I used the following protocol:
1) Step 1. I applied a molecular dynamic simulation using Standard Dynamics Cascade
2) Step 2. I analyzed molecular dynamics trajectory using the command Simulation | Analyze Trajectory
3) Step 3. Then, I used the protocol here: https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:ZS-F_AJlTfyGBneMANRkKQ/media:ssBFnMMrQkys9iZRbYnZNQ
So, I obtained the energy of binding but without standard deviations. the procedure that I have applied is it correct? how can I obtain the standard deviations of energy?
Thank you
Answers 5
JS
JS 2020-07-27
Hi Claudia, after you run the Binding Free Energy-Single Trajectory (using the Standard Dynamics Cascade output trajectory as input) you should have an output Molecule Window and in the Conformation tab you should see a 'DeltaG_*' column which is your calculated free energy for each conformation. You can copy that column into Excel to calculate the standard deviation.
CC
CC 2020-07-27
thank you :-)
CC
CC 2020-07-28
Hi, I have only one more question. what is the unit of measure of van der waals and electrostatic energy? because for delta G I suppose kcal/mol and it can be correct. my average deltaG is -160,887 ± 5,877  but the values  for van der waals and electrostatic energy are strange. the average for for van der waals is -1873,88 ± 24,418 and for electrostatic energy is  -20728,39 ± 122,22.
JS
JS 2020-07-28
Those terms are in units of kcal/mol. However, they are not the vdw and electrostatics of interaction those are the same values that are for the whole entire system during the MD simulation. If you look at your output dsv file from MD you will see those same values.
CC
CC 2020-07-28
thank you
