PURPOSE: Change the display style of the last active document so that the atom are represented by ball and stick which are colored with a RedWhiteBlue spectrum whose values are associated with the 'Isotropic Displacement' property and the BallSize is proportional to the value of the 'Isotropic Displacement'.
INSTALLATION: Save color_scale_ballsize_by_property.pl to a local directory or location accessible from the Files Explorer
USAGE:
From the DS Client: From the Files Explorer, double-click on the color_scale_ballsize_by_property.pl to launch the script or right-click on the file and select Open With | Script Window then launch the script using the Run command from the Scripting toolbar.
DISCLAIMER: This custom script is compatible with Discovery Studio 2.1. It is provided "as is" and is NOT supported by Accelrys nor is it warranted for any purpose whatsoever. The user assumes responsibility for any malfunctions or bugs.
EXPECTED RESULTS: When this script is run, the display style of the last active 3D window will be modified such that the atoms will be displayed as ball and stick with the ball size proportional to the Isotropic Displacement values and the atom coloring will be a variation of red, white or blue again depending on the atom's Isotropic Displacement value and a red, white and blue spectrum.
The attached .zip contains:
1. A README.txt
2. The color_scale_ballsize_by_property.pl DiscoveryScript
