LibDock problem
This must be quite trivial but I have not found the right way to do it. I am using LibDock (DS2020) to dock a collection of ligands into a receptor. I am finding that if I perform the regular docking with default parameters and without any minimization after docking, the calculation finishes and I get docked poses for every ligand. However, if I run LibDock selecting any of the available postdocking Minimization Algorithms that appear on the menu, then the calculation finishes raising an error and does not provide any result because it fails to minimize all of the docked ligands. I have also tried to minimize some of those using the In situ Ligand Minimization option, but with the same result. I do not understand what is wrong with this and DS2020 does not seem to provide any additional info that can drive me to fix the problem. Any help would be appreciated.
Answers 3
CB
CB 2021-07-14
Hi Jordi. You mentioned that the ligands are also failing to minimize with the In Situ Ligand Minimization protocol. Do you have an sd file in the Output folder of the run called _fail.sd? If you open this sd file in the DS client and look at the details for the ligands do you see an error text property listed? This can give information about what caused the issue with the minimization of the ligand.
JB
JB 2021-07-14
Ok, it looks like it was my receptor that had not been prepared adequately. Now it seems to work. Please disregard my post.
JB
JB 2021-07-14
Hi Carol. Thanks for your answer. As I just said, it looks like it was a problem of my receptor not being well prepared. Now it seems to work or at least is taking much longer to finish.
