I am trying to install DS 3.0 in linux and am unable to. When I run ./DS30Client.bin -is:log log.txt and look the log file is see the following output:
Log file created by MultiPlatform installer @Thu Dec 9 15:53:17 CST 2010
INSTALLER_PATH=/home/craig/Downloads/./DS30Client.bin
command line switch -is:javahome is specified. Verifying the JVM with the JVM files specifed with the launcher.
JVM specified with -is:javahome cannot be verified with the JVM files specified with the launcher. Environment Variables will be checked next...
Checking the environment variables specifed in the JVM files to find the JVM...
No JVM can be found using the shell environment variable. Searching JVM will continue with Path Hints specified in the JVM Files...
jvm files not specified. Searching a JVM can not be performed.
is not found. Error extracting bundled JRE. Failed to launch the application.
Any help with this error would be appreciated.
Thanks
