We have performed a structure-based pharmacophore (receptor whose ligand is not reported) in which, a large number of small molecules library is screened, depending upon their FitValue the small molecules are sorted, for further analysis. Cdocking protocol is performed for the ligands, further depending upon the -CDOCKER SCORE and -CDOCKER INTERACTION the ligand library is sorted. Meanwhile, ADMET and Toxicity are also checked for the ligand library.
For the lead optimization part, what do we select for "Input Fragment Libraries", What are the small molecules library do we select for the "De novo Library Generation"
If a receptor does not have a known inhibitor how do we perform De Novo or Lead optimization part for the same?
Hi Piyush. If you have not seen them already there are tutorials in the Help, which go through the setting up and running of the different De Novo design protocols. These describe the setup depending on whether you are docking different fragments to your protein without an existing ligand or modifying an existing ligand scaffold. The tutorials use fragment libraries that come with the software and are described in the Help. As you mentioned, you can also generate your own fragment libraries with the De Novo Library Generation protocol if you want to test particular fragments.
