I have a flexible docking related issue that I was hoping someone might have a solution for.
Many of my compounds have amidinium functional groups. I would like to model the positive charge as being delocalized over the two nitrogens and carbon. If I model the compound using partial double bonds, CHARMm seems to type the molecule and add charges correctly. However, when I try to do flexible docking, I get an message saying "No docking poses found." If I model my amidinium without any partial bonds (i.e. modelling a single resonance structure with a neutral nitrogen and a nitrogen with a formal +1 charge), the docking simulation runs fine and finds a great deal of docked poses. It seems that one can't input a molecule with partial double bonds into a docking simulation (aromatic bonds on the phenyl rings work fine, however). Is there any way around this? Is there a ways to assign custom charges to the atoms (I was thinking to reassign the CHARMm charges from the delocalized structure to the single resonance structure)? I've tried inspecting the atoms and changing the partial charges there, but that causes the docking simulation to not find any poses.
Thanks!
Scott Johnson
Houk Lab
UCLA
Thanks!
Scott Johnson
Houk Lab
UCLA
Charge delocalization in systems like this are handled by the server, all you should have to do is to make sure that the formal charges are correct, (i.e. that one of the Nitrogen atoms has a +1 charge). To see the charges that get used in the protocol, you can type the molecule with the CHARMm forcefield and label the atoms by partial charge, for amidines, you should see equal positive partial charge on the two NH2 pairs. As the internal file formats used may not support non-integer bond orders or charges the starting structure should indeed be a single resonance form.
This protocol does not currently support custom charges (though hopefully you won't need to use them). However you could create a custom protocol that works with different file formats (e.g. mol2) that support user charges.
Hope this helps,
Al
Thanks for the reply. I tried using the steps you explained, but it still seems to localize the positive charge on a single nitrogen.
I've outlined the steps I used to build the simplest example, which is just an amidinium substituted benzene.
1. From Tools->Visualization, I started with a benzyl fragment, which basically creates a toluene on the screen.
2. I deleted one of the methyl hydrogens, and substituted amino groups for the other two remaining hydrogens.
3. I changed one bond from single to double, then added a +1 charge to that nitrogen.
4. I did a Dreiding minimization to clean up the structure.
5. I typed the structure using Tools->Simulations->Forcefield->Apply Forcefield.
The partial charges show 0.0 on each nitrogen, but one has the +1 formal charge that I added. Just for reference, each nitrogen is typed identically as NP in CHARMm. Also, the hybridizations of the C and both Ns are correctly sp2.
Any ideas?
Thanks for the help!
Scott
As a general rule, sketching a single resonance form with integer charges and bond orders is the best way to handle ligands, the typing engine can then more easily figure out the chemistry and distribute the charges. The valency monitor (Structure->Monitor->Valency) can be useful in checking your formal charges and bond orders match up correctly.
Regards,
Al
