Hi all,
I used hypogen to generate 3D pharmacophore models of 43 small molecules. I have two doubts regarding them.
1) How to use CatScan to divide the dataset into training and test set. (My datasat molecule's activity values span 3 orders of magnitude and not 4, will there be a problem?) I also could not find CatScan option in DS2017R2.
2) How to get the predicted activity values of the test set molecules? (From the result I could only get the scatter graph showing the correlation of predicted vs the actual values but not the predicted values as such in a table.)
Because of the above doubts I am not able to generate good models.
Kindly reply as soon as possible.
dear Anu,
1) that is correct, there is no catScan in DS 2017 R2, or in any of the other versions I have currently in use. When did you use it or where did you hear about it; can you please provide a reference ?
We recommend an activity range of at least 4 orders of magnitude because of the way the HypoGen algorithm works.
After generating candidate hypotheses from the most active compounds, it inspects these pharmacophores in a second phase and eliminates the ones that fit too many of the inactive molecules, as these can not discriminate between the most and least active molecules. Here, a compound is considered inactive, if it is at least 3'163 times less active that the most active one. You can modify this default of 3.5 orders of magnitude, e.g. if, like in your case, it would lead to no or very few inactive compounds that can be used. Please be aware that this may incur the risk of removing valid hypotheses from further consideration. Please refer to the Pharmacophores tools > Theory - Pharmacophores > Pharmacophore generation > Generating predictive pharmacophores help page for an outline of the three phases of HypoGen. If you decide to reduce the default, further information on how to do this can be found in Standalone Applications > Catalyst > Using Catalyst > Catalyst Parameters (look for GenerateHypo.inactive.spread under Parameters affecting hypotheses).
2) The 3D QSAR Pharmacophore Generation protocol currently does not report the estimates for the Validation set; you get get them from running these compounds against the chosen hypothesis using Ligand Pharmacophore Mapping, or the Ligand Profiler, if you want to look at multiple pharmacophores in parallel.
The quality of the generated models depends to a large degree on the range and distribution of structures and activities in your data set. You can try tweaking the parameters as mentioned above, but it may be that there is not enough information in your set to generate good ones. Have you tried using all your 43 compounds as training set, i.e. without external validation ?
Kind regards,
Wolfgang
As previously mentioned in this post,Your second question has been addressed as Enhancement Request DSC-29404 in the 2020 release of BIOVIA Discovery Studio;
the 3D QSAR Pharmacophore Generation protocol now retains the individual results from mapping the compounds of the validation set onto the generated hypotheses.
