This protocol illustrates how to combine a Solvation component with Standard Dynamics Cascade component. The 'Update MSV After Simulation' component is used to make sure the output msv file contains the solvated molecule as well as the trajectory (after dynamics). Also, a DiscoveryScript component is used to provide an additional way of specifying the solvent sphere if that option is chosen. Instead of specifying a sphere radius, there is an option to specify a Minimum Thickness. This value is then added to half the largest extent of the molecule to produce a sphere radius.
