Calculate binding energies after CDOCKER
Dear,
I want to calculate which ligands are better to bind to the specific active site in enzyme.
I figured out calculating binding energies protocol gives helpful informations what I want.
However, I don't know how evaluate resulting values generating from binding energies without "In situ ligand minimization".
I met two problems as below;
(1) Although I didn't use any further calculation processes, the values have different results and tendency depended on which implicit solvent model used.
(2) As I knew, higher value of binding energies means better binding affinity, therefore, a ligand which has higher binding energy is better for specific enzyme, is it right?
Thank you in advance
Answers 1
JS
JS 2013-12-31
It is probably a good idea to perform the In Situ Minimization either within the Calculate Binding Energies protocol or as a separate step before it unless you know that the ligands are already in an optimized position and conformation. I would probably suggest using one of the GB methods or PBSA for the implicit solvent and you want to rank the complexes such that those with the lower energies are the ones that bind better.
