Building Blocks - Save DS selections from multi-compound SD file
This script is an example of how multiple compounds in a single .sd file can be processed, and then output to a single multi-compound .msv file.
Compare the syntax here to the related script, which loops through multiple .sd files and writes out individual .msv files:
Building Blocks - Save DS selections from all SD files in a folder.pl
Also, see how this can be used as a perl-on-server component in the following protocols:
Run Ligand Pharmacophore Mapping and save selected mapped atoms to a multi-compound .msv file
and
Run Ligand Pharmacophore Mapping and save selected mapped atoms to individual .msv files
Save this script to a local directory or location accessible from the DS Files Explorer
