Hi All,
I'm working with DS 2,5.
I set Dynamic equilibration (after a Dynamic heating) with the following parameters:
Steps 3000
Time step 0,001
Target temperature 300
Adjust velocity frequency 50
Save results frequency 100
Implicit solvent model GBIM
When it finished running I looked at Data Table
I get 50 conformation and steps were numbered in a strange way.
From 100 to 2000 then from 100 to 3000 (100...2000 100....3000).
According to these values time was going from 0,1 to 2 and from 0,1 to 3
Are there any mistakes? Why is not numeration steps going from 100 to 3000 as I expected?
I've tried to set steps to 1000 and I get steps going from 100 to 2000 and then from 100 to 1000.
The result of the dynamic heating was a dsv file with well numbered 2000 conformations .
I select the last conformation before running equilibration.
How can I use one conformation of the dsv obtained from heating,as input for dynamics equilibration?
Is it right to use the entire dsv, with all conformations, as input for dynamics equilibration?
I suppose it is right to use the conformation when equilibrium is reached.
How can I fix it?
Thank in advance
