Reads in a .sd/.sdf file and a .csv file containing IC50 values (one value per line). Creates and populates a new property in the .sd/.sdf file for the IC50 values. Finally, writes out the new .sd/.sdf file containing IC50 values.
Please refer to the comments in the header of the import_IC50_values.pl file for syntax and usage information.
Note, this script will work with DS 2.0.
