I'm trying to merge the 55 bodies of a blade into a single body using the combine tool. To create a single mesh in ANSYS, the blade must be a single body. I am not able to add all 55 bodies together as I get a a zero thickness geometry error. Is there any tool I can use to combine all of the bodies, or do I need to figure out a way to construct a single solid using the bodies as references? Any help or guidance is greatly appreciated. File is attached for reference.
As part of the migration from the legacy Forum to the new SOLIDWORKS Forum, there was an overlap in timing where the new Forum was being loaded with historical data from an export migration, while at the same time, the legacy Forum was still operating during the period of March 12th to March 31st. Due to the overlapping timelines and import-export technical issues, posts during that time-frame could not have their media imported. If you created a post in the legacy Forum during that time-frame and wish to update the post in the new Forum with supporting media, please go to your post in the new Forum, enter into Edit mode and re-add any supporting media you want to insert.
The easiest way to find your posted content is: from the new Forum, click on your profile icon in the top right of the GUI, then select "My Profile" and you will be taken to the "Overview" tab where you can see all of your posting history.
Thank you
