my vb.net program is running sw in the background, no probleminitially, as sw stay invisible while it opens some files andoutputs .dxf, .pdf versions ,etc.
...but then when the ActivateDoc2(....) method is called on anassembly, all of a sudden sw becomes visible in the backgound.
I have used
sldworks.UserControl = false
sldworks.visible = false
...right at the beginning of my code, and sw does stay invisiblefor quite a good portion of the processing, but when theActivateDoc2 () method is called to activate an assembly, swsuddenly makes itself visible?
code below:
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Imports SolidWorks.Interop.swpublished
Imports SolidWorks.Interop.swconst.swUserPreferenceIntegerValue_e
Imports SolidWorks.Interop.swconst.swDocumentTypes_e
Imports SolidWorks.Interop.swconst.swOpenDocOptions_e
Imports SolidWorks.Interop.swconst.swSaveAsOptions_e
Imports SolidWorks.Interop.swconst.swLoadExternalReferences_e
Imports SolidWorks.Interop.swconst.swPromptAlwaysNever_e
Imports SolidWorks.Interop.swconst.swUserPreferenceToggle_e
Imports System
Imports System.IO
Module Module1
Dim app As SldWorks
Dim log As StreamWriter
Sub Main(ByVal CmdArgs() As String)
Dim model As ModelDoc2
Dim fileName As String
Dim topModel As ModelDoc2
Dim errs As Long
Dim warns As Long
Dim retVal As Long
Dim ArgNum As Integer
Dim logName As String = "c:\\swexport.log"
If File.Exists(logName) Then
File.Delete(logName)
End If
log = File.CreateText(logName)
If CmdArgs.Length < 1 Then
Console.WriteLine("Usage: swexport filename")
log.WriteLine("swexportfailure")
log.Close()
Exit Sub
End If
' app = New SldWorks
app = CreateObject("SldWorks.Application")
Dim ret As Boolean
' Set user preferences.
ret = app.SetUserPreferenceIntegerValue(swLoadExternalReferences,swLoadExternalReferences_None)
ret =app.SetUserPreferenceIntegerValue(swPerformanceAssemRebuildOnLoad,swResponseNever)
ret =app.SetUserPreferenceIntegerValue(swLargeAsmModeAutoActivate,swResponseNever)
app.SetUserPreferenceToggle(swEDrawingsOkayToMeasure, True)
'app = CreateObject("SldWorks.Application","dbremne0d10eng.eng.emc.com")
'app = GetObject("SldWorks.Application")
app.UserControl = False
app.Visible = False
app.LoadAddIn("C:\\Program Files\\Bluebeam Software\\PushbuttonPDF\\SolidworksLt\\BbSldWksPdfLt.dll")
'Console.WriteLine("Attempted to load PDF addin. Status " +retVal.ToString)
fileName = CmdArgs(0)
Dim blankstring As String = String.Empty
' Determine document type based on file extension.
Dim fileExt As String
Dim docType As Long
fileExt = Right(fileName, 6)
Select Case fileExt
Case "sldprt"
docType = swDocPART
Case "sldasm"
docType = swDocASSEMBLY
Case "slddrw"
docType = swDocDRAWING
End Select
' Open document.
log.WriteLine("Opening " + fileName)
log.Flush()
Console.WriteLine("Opening " + fileName)
model = app.OpenDoc6( _
fileName, _
docType, _
swOpenDocOptions_Silent, _
blankstring, _
errs, _
warns _
If model Is Nothing Then
log.WriteLine("Unable to open " + fileName)
log.Flush()
Console.WriteLine("Unable to open " + fileName)
log.Close()
cleanUp()
Exit Sub
End If
log.WriteLine("Opened " + fileName)
log.Flush()
topModel = model
' Export the document to the appropriate format.
exportDoc(model)
' If the document is a drawing, export the models associated witheach
' view of each sheet.
If docType = swDocDRAWING Then
exportDrwRefs(model)
End If
log.WriteLine("swexportsuccess")
log.Close()
' Release memory.
' app.QuitDoc(topModel.GetTitle)
app.CloseAllDocuments(True)
topModel = Nothing
cleanUp()
End Sub
Sub exportDoc(ByVal model As ModelDoc2)
Dim docType As Long = model.GetType
Dim errs As Long
app.Visible = False
app.ActivateDoc2(model.GetTitle, True, errs) ' Activate model
app.Visible = False
' Export appropriate files.
Select Case docType
Case swDocPART
exportModel(model, "step")
'exportModel(model, "igs")
exportModel(model, "stl")
exportModel(model, "eprt")
Case swDocASSEMBLY
exportModel(model, "easm")
Case swDocDRAWING
exportModel(model, "pdf")
exportModel(model, "dxf")
exportModel(model, "edrw")
End Select
End Sub
Sub exportModel(ByVal model As ModelDoc2, ByVal format As String)
Dim sPathRoot As String
Dim sPathName As String
Dim retVal As Boolean
Dim errs As Long
Dim warns As Long
sPathRoot = model.GetPathName ' Get path and file name
sPathRoot = Left(sPathRoot, Len(sPathRoot) - 6) ' Strip fileextension
sPathName = sPathRoot + format ' Add new file extension
log.WriteLine("Writing " + sPathName)
log.Flush()
Console.WriteLine("Writing " + sPathName)
' Export model.
retVal = model.SaveAs4( _
sPathName, _
0, _
swSaveAsOptions_Silent, _
errs, _
warns _
log.WriteLine("Status " + retVal.ToString)
log.Flush()
Console.WriteLine("Status " + retVal.ToString)
End Sub
Sub exportDrwRefs(ByVal model As ModelDoc2)
model.Visible = False
' Collect the models referenced by this drawing.
Dim drwRefs As New Hashtable
Dim drawing As DrawingDoc = model
Dim sheetNames As Object = drawing.GetSheetNames
Dim i As Integer
For i = 0 To UBound(sheetNames) ' Traverse drawing sheets
drawing.ActivateSheet(sheetNames(i))
Dim view As SolidWorks.Interop.sldworks.View
view = drawing.GetFirstView
While Not view Is Nothing ' Traverse sheet views
model = view.ReferencedDocument ' Get model referenced by view
If Not model Is Nothing Then
Console.WriteLine("Found drawing model " + model.GetTitle + _
" in " + view.Name)
' Add models to hash to get unique file names.
If Not drwRefs.ContainsKey(model.GetTitle) Then
drwRefs.Add(model.GetTitle, model)
End If
End If
view = view.GetNextView
End While
Next
' Export drawing references.
Dim enumerator As IDictionaryEnumerator = drwRefs.GetEnumerator()
While enumerator.MoveNext()
exportDoc(enumerator.Value)
End While
End Sub
Sub cleanUp()
app.ExitApp()
app = Nothing
GC.Collect()
End Sub
End Module
SolidworksApi macros
I have used
code below:
Imports System
Imports System.IO
Module Module1
Dim app As SldWorks
Dim errs As Long
Dim warns As Long
Dim retVal As Long
End If
log.Close()
Exit Sub
End If
Dim ret As Boolean
app.Visible = False
Dim docType As Long
Select Case fileExt
Case "sldprt"
docType = swDocPART
Case "sldasm"
Case "slddrw"
End Select
' Open document.
log.Flush()
fileName, _
docType, _
blankstring, _
errs, _
warns _
log.Flush()
log.Close()
cleanUp()
Exit Sub
End If
log.Flush()
topModel = model
exportDoc(model)
End If
log.Close()
' Release memory.
topModel = Nothing
cleanUp()
End Sub
Dim errs As Long
app.Visible = False
app.Visible = False
Select Case docType
Case swDocPART
Case swDocASSEMBLY
Case swDocDRAWING
End Select
End Sub
Dim errs As Long
Dim warns As Long
log.Flush()
' Export model.
sPathName, _
0, _
errs, _
warns _
log.Flush()
End Sub
Dim i As Integer
" in " + view.Name)
End If
End If
End While
Next
End While
End Sub
Sub cleanUp()
app.ExitApp()
app = Nothing
GC.Collect()
End Sub
End Module
