Hello Forum,
I am trying to create a mold using a part that was generated using the Intersection command. I drew the
real part I need. Closed the open end/area with a plane and then using the Intersection command came up
with a new part (yellow) that is the core pattern for my mold. I saved the core pattern as a part. Started new drawing to make a "box" around the core pattern so I can make a core box for casting a sand core. But for some reason I cannot
select the core part (Yellow) and make it disappear like I was able to do when I first started this project?
Is it possible to select an Intersection as a part? Is there some way I can save the intersection (yellow)
part to another file as a solid or some other form so it does not show as an Intersection in my drawing tree
but as a real, self contained part?
Thanks,
As part of the migration from the legacy Forum to the new SOLIDWORKS Forum, there was an overlap in timing where the new Forum was being loaded with historical data from an export migration, while at the same time, the legacy Forum was still operating during the period of March 12th to March 31st. Due to the overlapping timelines and import-export technical issues, posts during that time-frame could not have their media imported. If you created a post in the legacy Forum during that time-frame and wish to update the post in the new Forum with supporting media, please go to your post in the new Forum, enter into Edit mode and re-add any supporting media you want to insert.
The easiest way to find your posted content is: from the new Forum, click on your profile icon in the top right of the GUI, then select "My Profile" and you will be taken to the "Overview" tab where you can see all of your posting history.
Thank you
