How to improve performance of vast (thousands +) hole pattern?
Hello guys, our production usually have thousands of hole pattern, the structure is not complex, but holes count is vast. There is a performance problem that any operation would be very slow and easy to crash, and the adding drawing dimension would be tortured... Here's the way I have tried, anybody have a better advise?
  1. Use freeze bar to freeze the pattern feature.
  2. Don't built big pattern feature, just add pattern circle sketch to replace the actual feature, just show the hole outline and position.
All the way below is not perfect, it's very slow anyway, if use sketch, the model is faster but the drawing would be slower, and the appearance is not very well compared with the actual hole pattern feature. We need to show all holes and there dimension both in part drawing and assembly drawing, Any better way to create vast hole pattern more effectively?
As part of the migration from the legacy Forum to the new SOLIDWORKS Forum, there was an overlap in timing where the new Forum was being loaded with historical data from an export migration, while at the same time, the legacy Forum was still operating during the period of March 12th to March 31st. Due to the overlapping timelines and import-export technical issues, posts during that time-frame could not have their media imported. If you created a post in the legacy Forum during that time-frame and wish to update the post in the new Forum with supporting media, please go to your post in the new Forum, enter into Edit mode and re-add any supporting media you want to insert.
The easiest way to find your posted content is: from the new Forum, click on your profile icon in the top right of the GUI, then select "My Profile" and you will be taken to the "Overview" tab where you can see all of your posting history.
Thank you
