I have written an add-in for EPDM that allows you toautomatically rename a file with a serial number and drop theprevious name into the description variable using VB.NET. This isfor using old files that were named with a description.
However, each time you run the add-in you must drill down to thefile location using the FileBrowserDialog. Is there a way that whenI select a file before I run an add-in that the add-in will knowwhich file the user has selected or at least the folder that theuser is in.SolidworksApi macros
