1. When zoomed up on an area (say to apply a specificcolor/material to a face, side of a feature that's to hard toselect zoomed out), is there a way to stop the processing of theentire scene > you really only want the area you are zoomed upon so you can determine if the material you are applying is whatyou want? Or the ability to just process a windowed area like PW.Even using the Esc key to stop everything while you apply yourselection would be nice? However, it appears when you select theviewport (non geometry) the processing stops?
2. Material prop area - When selecting a face, body etc..it doesn'tdisplay the current applied material? So if I have satin low glossplastic it would be nice if the dialog would display this in somemanner. Also, when adjusting texture scale multiplier or bumpstrength it doesn't appear to do much? When adjusting the texturemultiplier if you input say 50%, then 500% then -200% the scalecontinues to "grow" (looks like Jupiter). You can't obtain a nicetight (smaller) scale or larger scale on demand, it just seems toget lost?
3. How to change the orientation of a material e.g. a mappingdialog to adjust orientation similar to PW or SW appearances?
4. Views similar to SW - The ability to save view orientations,recall last view (not last render)?
5. Decals/pics not showing up - a sketch image applied in a SWsketch does not appear to be showing up?
6. Just for clarification, when you save a file in 360, it appearsto be storing all of its "info" in the SW native file similar toCosmos? So in an assy for example, you don't need any of the refparts?
SolidworksPhotoview 360
