I have attempted to put together a macro that will reattach BOM balloons in a drawing to whatever object is exactly where the arrow head is. This is used to correct dangling balloons when I restructure the assembly hierarchy.
I am running Solidworks 2019 service pack 4.0
First the BOM Balloon needs to be selected and then when the macro is run it is supposed to reattach the balloon to the new object in the same location.
--The problem is that when I save and reopen the drawing the attachment point (and balloon) move to the end point of the object instead of staying at the selected point.
Although I set the leader attachment point, this doesn't survive a save and reopen. Is this a bug? or is there some other way to include the attachment point when setting the attached entities? Any help would be greatly appreciated.
Option Explicit
Sub main()
Dim swSelMgr As SldWorks.SelectionMgr
Dim swSelObj1 As Object
Dim swAnn As SldWorks.Annotation
Dim Boolstatus As Boolean
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swSelObj1 = swSelMgr.GetSelectedObject6(1, -1)
Set swAnn = swSelObj1.GetAnnotation
Boolstatus = ReattachBalloon(swModel, swAnn)
End Sub
Function ReattachBalloon(swModel As SldWorks.ModelDoc2, swAnn As SldWorks.Annotation) As Boolean
Dim swAnnPos As Variant
Dim swArrowPos As Variant
Dim swObject As Object
Dim swDisplayData As IDisplayData
Dim swSelMgr As SelectionMgr
Dim swSelObj2 As Object
Debug.Print ""
Debug.Print " Annotation Type = " & swAnn.GetType & "; Annotation Name: " & swAnn.GetName
'==========get annotation position==========
swAnnPos = swAnn.GetPosition
Debug.Print "Annotation Position: " & Str(swAnnPos(0)) & ", " & Str(swAnnPos(1)) & Str(swAnnPos(2))
'==========get arrow position==========
Set swObject = swAnn.GetDisplayData
Set swDisplayData = swObject
' If Not swDisplayData Is Nothing Then
Dim swWeldSymbolAnn As WeldSymbol
Dim Suitable As Boolean
Suitable = True
If swAnn.GetType = swWeldSymbol Then
Set swWeldSymbolAnn = swAnn.GetSpecificAnnotation
Debug.Print "number of arrowheads: " & swWeldSymbolAnn.GetArrowHeadCount & "; number of leaders: " & swWeldSymbolAnn.HasExtraLeader
If swWeldSymbolAnn.GetArrowHeadCount = 0 Then
Suitable = False
End If
End If
Debug.Print "multijog leader count: " & swAnn.GetMultiJogLeaderCount & "; smart arrow head?: " & swAnn.GetSmartArrowHeadStyle
swArrowPos = swDisplayData.GetArrowHeadAtIndex(0)
Boolstatus = IsEmpty(swArrowPos)
' If Not IsEmpty(swArrowPos) Then
Debug.Print "bent leader = " & swAnn.GetBentLeader & "; get leader = " & swAnn.GetLeader
' If swAnn.GetLeader And Not swAnn.GetBentLeader Then
If swAnn.GetLeader And Suitable Then
Debug.Print "number of arrowheads: " & swAnn.GetArrowHeadCount & "; number of leaders: " & swAnn.GetLeaderCount & swAnn.BentLeaderLength
Debug.Print "Arrow Position: " & Str(swArrowPos(0)) & ", " & Str(swArrowPos(1)) & Str(swArrowPos(2))
' End If
' Else
' MsgBox "Could not get display data for this object"
' End If
'==========get object to attach to==========
Boolstatus = swModel.Extension.SelectByRay(swArrowPos(0), swArrowPos(1), swArrowPos(2), 0, 0, -1, 0.001, 1, True, 0, 0)
If Boolstatus = False Then
Boolstatus = swModel.Extension.SelectByRay(swArrowPos(0), swArrowPos(1), swArrowPos(2), 0, 0, -1, 0.000000001, 2, True, 0, 0)
End If
If Boolstatus Then
Debug.Print "selected object count " & Str(swSelMgr.GetSelectedObjectCount)
Set swSelObj2 = swSelMgr.GetSelectedObject6(swSelMgr.GetSelectedObjectCount, -1)
Debug.Print "object to attach to type " & swSelObj2.GetType
'==========attach annotation to object==========
Dim AttEntArr(0) As Object
Set AttEntArr(0) = swSelObj2
Dim vAttEntArrIn As Variant
vAttEntArrIn = AttEntArr
Debug.Print "get attached entities count: " & swAnn.IGetAttachedEntityCount & " type: " & swAnn.IGetAttachedEntityTypes
'Dim swtempObject As Object
'Set swtempObject = swAnn.IGetAttachedEntity
Boolstatus = swAnn.SetAttachedEntities(vAttEntArrIn)
'==========reposition annotation and arrow==========
Boolstatus = swAnn.SetPosition(swAnnPos(0), swAnnPos(1), swAnnPos(2))
Boolstatus = swAnn.SetLeaderAttachmentPointAtIndex(0, swArrowPos(0), swArrowPos(1), swArrowPos(2))
Else
MsgBox "could not find object to attach to"
End If
End If
End Function
SolidworksApi/macros
