Hello fellows,
I've been trying to write a VBA macro to assign layers to a big drawing (i.e. many section views) of a relatively big assembly. It does work, except that it takes a fair amount of time to finish the process. For every "child" assembly it assigns a layer to it takes around 5 minutes, which is a lot, let alone the fact that the computer gets unbearably slow.
To assign all the layers I need it takes several hours, so it is impractical.
Can anyone help me to speed things up?
Here's the code:
Dim swApp As Object
Dim swDwg As SldWorks.DrawingDoc
Dim sheet1 As Sheet
Dim swLayerMgr As SldWorks.LayerMgr
Dim swSelMgr As SldWorks.SelectionMgr
Dim BA As Integer
Dim AnelPressao As Integer
Dim Bandagem As Integer
Dim Calco As Integer
Dim supLat As Integer
Dim Travessa As Integer
Dim contador As Integer
Dim swView As SldWorks.View
Dim swSubView As SldWorks.View
Dim dwgView As Feature
Dim swDrawComp As SldWorks.DrawingComponent
Dim pecas As Variant
Dim peca As Variant
'Dim peca As SldWorks.Entity
Sub main()
Set swDwg = swApp.ActiveDoc
Set swLayerMgr = swDwg.GetLayerManager
IModelView:: EnableGraphicsUpdate = False
swDwg.Visible = False
BA = swLayerMgr.AddLayer("BARRA DE APERTO", "", RGB(0, 255, 255), 0, 0)
AnelPressao = swLayerMgr.AddLayer("ANEL DE PRESSÃO", "", RGB(0, 255, 0), 0, 0)
Bandagem = swLayerMgr.AddLayer("BANDAGEM", "", RGB(128, 0, 255), 0, 0)
Calco = swLayerMgr.AddLayer("CALÇO", "", RGB(128, 128, 0), 0, 0)
supLat = swLayerMgr.AddLayer("SUPORTE LATERAL", "", RGB(255, 0, 0), 0, 0)
Travessa = swLayerMgr.AddLayer("TRAVESSA", "", RGB(0, 128, 128), 0, 0)
If Not swDwg Is Nothing Then
Set sheet1 = swDwg.Sheet("Folha1")
Set swView = swDwg.GetFirstView
Set swSubView = swView.GetNextView
Do While Not swSubView Is Nothing
DoEvents
Debug.Print swSubView.Name
On Error Resume Next
Set swDrawComp = swSubView.RootDrawingComponent
pecas = swDrawComp.GetChildren
'For i = 0 To 2
For Each peca In pecas
'MsgBox peca.Name
DoEvents
Debug.Print peca.Name
For j = 1 To 10
If peca.Name = "CORE_AND_COIL-" & j & "/CLAMP_ASSEMBLY-1" Then
peca.Layer = "BARRA DE APERTO"
End If
If peca.Name = "CORE_AND_COIL-" & j & "/YOKE_BANDAGE-1" Then
peca.Layer = "BANDAGEM"
End If
If peca.Name = "CORE_AND_COIL-" & j & "/CLAMP_RING_UPPER-1" Then
peca.Layer = "ANEL DE PRESSÃO"
End If
If peca.Name = "CORE_AND_COIL-" & j & "/CLAMP_RING_LOWER-1" Then
End If
If peca.Name = "CORE_AND_COIL-" & j & "/UPPER_SUPPORTS_ASSEMBLY-1" Then
peca.Layer = "CALÇO"
End If
If peca.Name = "CORE_AND_COIL-" & j & "/LOWER_SUPPORTS_ASSEMBLY-1" Then
End If
Dim numLetra As String
numLetra = j
If ((InStr(peca.Name, "BUMPER") > 0) And (InStr(peca.Name, numLetra) > 0)) Then
peca.Layer = "SUPORTE LATERAL"
End If
If ((InStr(peca.Name, "CROSSBAR") > 0) And (InStr(peca.Name, numLetra) > 0)) Then
peca.Layer = "TRAVESSA"
End If
'Debug.Print j
Next
Next
' If swSelObj.Name = "UPPER_CLAMP_PLATE_BT-1" Then
' swSelObj.Layer = "BARRA DE APERTO"
' End If
Set swSubView = swSubView.GetNextView
Loop
End If
'For Each peca In swDwg
' If peca.ModelName = "UPPER_CLAMP_PLATE_BT" Then
' peca.Layer = "BANDAGEM"
' End If
'Next
swDwg.Visible = True
Debug.Print "END"
End Sub
SolidworksApi/macros
