I made this macro which will hyperlink the BOM balloon to the file with the same name as shown in it's corresponding Part Number field in the BOM, assuming the drawing exists in the same directory of the Part being linked.
FYI, Hyperlinks remain active in PDF's, so a PDF reader will try to open the SolidWorks links in the native SolidWorks application, so a modification may be necessary to link PDFs to PDFs.
' Preconditions:
' 1. Add "Microsoft Scripting Runtime" to References for "file exist"
' Postconditions:
' 1. Links all balloons to drawing with the same name & location as the item in BOM
' NOTE:
If Not swModel.GetType = swDocDRAWING Then
MsgBox "Must run macro in drawing only."
End
End If
Dim swDrawDoc As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swNote As SldWorks.Note
Dim sheetCount As Long
Dim viewCount As Long
Dim noteCount As Long
Dim swSelectionMgr As SldWorks.SelectionMgr
Dim swAnnotation As SldWorks.Annotation
Dim swBomTableAnnotation As SldWorks.BomTableAnnotation
Dim swBomBalloonParams As SldWorks.BalloonOptions
Dim i, j As Long
Dim swBalloon As SldWorks.BalloonOptions
Dim strLink() As String
Dim strFilePath As String
Dim strFileName As String
Dim strDocName As String
Dim NameSegs() As String
Dim strExtension As String
Sub main()
strExtension = ".SLDDRW"
Set swModel = swApp.ActiveDoc
Set swDrawDoc = swModel
strFilePath = Left(swModel.GetPathName, Len(swModel.GetPathName) - 21)
strDocName = Mid(swModel.GetPathName, Len(strFilePath) + 1)
Dim swFeat As SldWorks.Feature
Dim swTableAnn As SldWorks.TableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
If swFeat.GetTypeName = "BomFeat" Then
If Not swBomFeat Is Nothing Then
MsgBox "More than one BOM has been detected." & vbCrLf & _
"Only the first BOM will be used for balloon hyperlink."
Exit Do
End If
'http://help.solidworks.com/2019/english/api/sldworksapi/get_components_in_each_bom_table_row_vb.htm
Set swBomFeat = swFeat.GetSpecificFeature2
Dim vTableArr As Variant
Dim vTable As Variant
Dim vConfigArray As Variant
Dim vConfig As Variant
Dim ConfigName As String
Dim swTable As SldWorks.TableAnnotation
Set swFeat = swBomFeat.GetFeature
vTableArr = swBomFeat.GetTableAnnotations
For Each vTable In vTableArr
Set swTable = vTable
vConfigArray = swBomFeat.GetConfigurations(True, True)
For Each vConfig In vConfigArray
ConfigName = vConfig
Set swTableAnn = swTable
Dim nNumRow As Long
Dim nNumColumn As Long
nNumRow = swTableAnn.RowCount
ReDim strLink(nNumRow) As String
Set swBOMTableAnn = swTableAnn
For j = 0 To nNumRow - 1
Dim vPtArr As Variant
Dim swComp As Object
Dim pt As Object
vPtArr = swBOMTableAnn.GetComponents2(j, ConfigName)
If (Not IsEmpty(vPtArr)) Then
For i = 0 To UBound(vPtArr)
Set pt = vPtArr(i)
Set swComp = pt
If Not swComp Is Nothing Then
strLink(j) = (Left(swComp.GetPathName, Len(swComp.GetPathName) - 7) & strExtension)
If Not UCase(Left(swComp.ReferencedConfiguration, 7)) = "DEFAULT" Then
NameSegs = Split(strLink(j), "\\")
strLink(j) = Left(strLink(j), Len(strLink(j)) - Len(NameSegs(UBound(NameSegs)))) & swComp.ReferencedConfiguration & strExtension
End If
Else
Debug.Print " Could not get component" & j & "."
End If
Next
End If
Next j
Next vConfig
Next vTable
End If
Set swFeat = swFeat.GetNextFeature
Loop
If swBomFeat Is Nothing Then
MsgBox "No BOM Found"
End
End If
'get balloons and add hyperlink based on findings above
viewCount = swDrawDoc.GetViewCount
Dim ss As Variant
ss = swDrawDoc.GetViews
For sheetCount = LBound(ss) To UBound(ss)
Dim vv As Variant
vv = ss(sheetCount)
For viewCount = (LBound(vv) + 1) To UBound(vv)
Dim vNotes As Variant
noteCount = vv(viewCount).GetNoteCount
If noteCount > 0 Then
vNotes = vv(viewCount).GetNotes
For i = 0 To noteCount - 1
Set swNote = vNotes(i)
If swNote.IsBomBalloon Then
Set swAnnotation = swNote.GetAnnotation
swAnnotation.Select3 False, Nothing
Dim intMethod As Integer
If swNote.GetBomBalloonTextStyle(True) = swDetailingNoteTextItemNumber Then
If fso.FileExists(strLink(swNote.GetBomBalloonText(True))) = True Then swNote.SetHyperlinkText (strLink(swNote.GetBomBalloonText(True)))
End If
swModel.ClearSelection2 True
End If
Next
End If
Next viewCount
Next sheetCount
swModel.EditRebuild3
End SubHopefully others can use this to make drawing navigating more convenient. If you make variations to this code, please paste into the comments.
SolidworksApi/macros
