Drop Tests 101 with Explicit Dynamics on 3DEXPERIENCE PLATFORM
Whether you're designing a smartphone, sensor, packaging system, or industrial tool—drop testing is a critical part of ensuring product durability and performance under real-world conditions.
3DEXPERIENCE platform enables a streamlined, end-to-end workflow for conducting Explicit Dynamics drop test simulations, and here's what makes it stand out:
Integrated Preprocessing Capabilities:
  • Create rigid abstraction shapes (e.g., floor surfaces) for impact definition.
  • Mesh complex assemblies with precision.
  • Apply boundary conditions, contact definitions, and gravity loading—all in one collaborative environment.
Powerful Post-Processing Tools:
  • Visualize stress, strain, and deformation to identify critical failure regions.
  • Analyze time-dependent responses like impact force and acceleration.
  • Use animations, section cuts, and contour plots to interpret results and communicate design performance clearly.
Accelerated Design Iteration:
  • Quickly implement and validate design modifications within the same platform.
  • Reduce the need for physical prototypes by using simulation insights early in the development cycle.
  • Foster better collaboration between design, engineering, and simulation teams—all connected through the cloud.
💡 Whether you're in consumer electronics, automotive, packaging, industrial equipment, or aerospace, leveraging simulation-driven design in 3DEXPERIENCE can lead to faster development, fewer test failures, and more resilient products.
Are you using virtual drop testing in your product development process? Do check out this post as well:
