Parametric Floor with Paths - ready to use
Are you working on a new factory layout? Do you want to update your demo with a realistic-looking floor? Is it hard to find a model that suits your needs?
I have an answer to all these needs! With the parametric floor, you can easily adapt it to your factory layout in just a few clicks. What's more, you can simply create paths with caution tape between workcells by drawing lines in one sketch and the floor will automatically rebuild.
How to use it?
  1. To modify overall geometry of the floor, use the parameters called: Plane **.
  2. To modify  the width of the walkways (overall, caution tape width included on both sides of the walkway), change parameter: Walkways Width.
  3. To modify the width of the caution tape, change parameter: Caution Tape Width.
  4. To modify walkways routing, edit Sketch.1 in Geometrical Set.1. Draw lines that represents centerline of the walkway.
Video tutorial:
3dxml:
