After adding arc welding weaving in 2025xFD03, we are now adding multipath arc welding in R2026GA.
VALUE :
Simulate the actual weaving motion or multiple robot weld paths along a single contour performed by arc welding robots which is used for welding thick metals and for filling wide, flat joints.
Allows to detect collision and get an accurate cycle time estimation.
Allows to build the arc welding task in the Robotics Arc welding apps or from the Bead fastener in the design structure.
HIGHLIGHTS :
Creates a multi-pass robot trajectory along a single contour
Easily create the initial Root Pass (the standard trajectory) and then additional passes inside a single interface
Define weld parameters such as Flip Direction, Base Offset, Wall Offset, Approach Distance, and Depart Distance
Here is a short video showing the new multi path in action:
This enhancement is available in all roles dedicated for Arc welding
Robot Programmer (RBS)
Fabrication Robot programmer (RFP)
Body-in-White Robot Programmer (RBWPR)
- Body-in-White Robotics Engineer (RBWRT)
- Fabrication Robot Workcell Programmer for Industrial Equipment (RARWI)
