I present a workflow around the fasteners from the product structure to the robot programming . A lot of improvement have been made since the V6r2013x Ga to this HF22 which permit to show how to manage the fasteners through a fluent workflow.
I let you see the video, the main topics showed are :
- Automatic fastener distribution in the assembly graph (PRD)
- Rough fastener distribution with the system assignment assistant (MSD)
- Robot + gun accessibility . Fastener orientation definition (TSA)
- Robot task creation for each robot (SpotWelding)
- Fastener distribution modification through TSA functionality (TSA)
- Robot task update (SpotWelding)
4 axis of works have been made since the v6r2013x Ga :
- Simplification and decreasing the number of clicks. Example :
- When you go in the TSA workbench, you are already in the live mode
- When you select a triangle in the result panel the gun is automatically snaped on.
- You can select in the gantt the general operation and automatically all the fasteners below fill the corresponding function ...
- Selection of the fastener directly in the 3D (by trap or fastener individually)
- Automatization of certain tasks. Example :
- After an assignment, the fastening operation is automatically moved from a general operation to an other. This is new since HF22 and permit to really do the most important job for the planner.
- The product build in TSA and in spotwelding is an important way of progress for a fluent workflow between planning and robotic especially to be able to treat the product change management.
- Automatic re-orientation of a set of fasteners in the results panel (not shown in the video)
- Find the right way to use the PPR context by using the right object and the right relation to take advantage of the functionality. Example :
- Usage of general operation implemented by the station resource for the position (Where) and implemented also by a robot for the fastener distribution (who). This organization permit to avoid to set a position at each new operation created.
- The right scope organization inside the PPR to permit the multi user works.
- Fix the bugs with a permanent dialog, test and correction made quickly (short loop)
Of course R&D continue to improve the solution on this 4 axis and all of these functionalities are also available on the level r2014 and r2014x
0
