⚠️ Watch 3D causing issues ⚠️
We have identified that the "Watch 3D" operator is causing serious issues since the 26x release :
  • Interrupting updates;
  • Unintended updates (which, combined with the previous issue, gives the impression that the update stops and restarts, but sometimes it does not restart);
  • Slowdowns.
We will work to deploy a fix in production as quickly as possible, but this may require some days or weeks. Simply disabling these operators is not enough to avoid the problem. The only available workarounds are:
  • Insert a "Relay" before the "Watch 3D" operators and set it to "off" or disable it;
  • OR disconnect the Watch 3D operators;
  • OR remove the Watch 3D operators.
We apologize for the inconvenience and will keep you informed about the availability of a fix.
