3D TAG bug?
Hi all,
I was playing about with extracting parameter values from geometry and in my case I have point with additional params attached to it reading that value and creating a 3D tag with said value.
However..
I find that the only way to get the tag note to update on a value change of the param value (which doesn't always mean a point change), is to modify the point in some small way such as changing it's X value for example.
Is this expected or a bug? If i do a "force update" update on the design sequence that works, but that's differing behaviour to geometric outputs and what if the params are to influence a geometric output?
This bug seems the same even for a VS reading params on the tree itself, they wont update.
