Using DataHub with DOORS classic and the available settings/menus
I'm looking for extra information on DataHub settings and Menus and cant quite figure out the interfaces from the help info on the website.
See the available DataHub-Cameo setting available to you in 2021xR2HF5:
https://docs.nomagic.com/display/CDH2021xR2/General
Here are the settings for DOORS (classic) which is what I am using to get objects from:
https://docs.nomagic.com/display/CDH2021xR2/IBM+Rational+DOORS
Main Question:
There is an oddity I have not been able to figure out how it keeps happening where the "default options" for all of the DataHub setting shown above keep resetting back to their defaults. It doesn't seem to be related to reboots or restarts of the application but it doesn't always happen, in fact, it happens rarely. But that it happens at all is an issue. I need to make sure Cameo opens the DOORS connection in read only mode and when this defaults back to its defaults, it opens DOORS in write-enabled mode.
Can anyone else confirm this happens to them or can the Cameo team please provide some advice how to lock these settings down so they cannot revert to their defaults?
1 more question:
How do you open (REOPEN) the "Copy Data with Sync" (DataHub Schema & direction) dialog seen in [#3] here after its initial use???
https://docs.nomagic.com/display/CDH2021xR2/Copy+Data+with+Sync+operations
I can only ever get to that window ONCE, which is on its first use when trying to bring in a new data source? The issue is that sometimes you need to make changes and this is the only time to do it as a complete set? The Schema Map Manager does not include all of these settings. See screen:
https://docs.nomagic.com/display/CDH2021xR2/Mapping+with+Schema+Map+Manager
