Dear Community Members,
@MK is inviting users to his live Masterclass session "Automated Tests in Modelica with Dymola and the Testing Library".
Let's connect and learn new things on September 18, at 3:00 PM CET. The duration of the session is up to 1 hour including the Q&A.
Join us in this masterclass session to level up your skills in Modelica testing and build models on a professional level!
Reliable testing methods are key for robust and reliable software development, including Modelica models. With every change or addition to a model or used libraries, unwanted side effects might be introduced which can lead to new results. Instead of relying on changelogs, use your own tests to get confident that everything behaves as it should.
Did you know that Dymola is equipped with everything you need to perform unit tests on Modelica models, both locally and on build automation servers? It ships with the Testing library, which was designed to test all kinds of Modelica classes.
In this masterclass we show you the Testing library's capabilities and how to use it. We will create tests in Dymola and demonstrate the various possibilities to check result values and trajectories. Next, we will run the tests, first individually inside Dymola, then automated with PowerShell scripts. From there it's only a small step to check for regressions with Jenkins, GitlabCI, etc.
https://www.youtube.com/watch?v=wnk5YbEgTjM
The Masterclass is open for everyone! There will be live stream here, in this post.
As usual, this Masterclass will be live on LinkedIn, and here in this post! x
To share the information with your network, I invite you to also promote the event on LinkedIn by using the LinkedIn event.
