Generalizations to update instances and see if requirement are met
This is a LEARN/DO project that I'm working thru to try and deep dive some ideas, I've included a screen shot of the specific area I'm trying to figure out. not sure it can even be done. (using 2021x R2) What I would like to model is having the requirement "look" at the HELE block for the "satisfy" ( I know the satisfy arrow is missing in the screen shot and there is no value in the HELE block currently, i cleaned up a mess before the screen shot to hopefully make my request clearer), AND the pass/fail be determined on whether I select P_One or P_Two using the utility of the Variables area when running a simulation to Remove/add value. to change which Generalization block I want to point at. Maybe something that can't be done, the end goal is to be able to (using the utility of the Variables area when running a simulation to Remove/add values to be able to "test" different config variables against requirements.
