Automatic Test Campaign with STIMULUS
Developing a Test Plan means identify numerous Use Case that should be turned into Test Scenarios. These Test Scenarios are used by STIMULUS to generate numerous combinations of input data.
How can you:
  • Select multiple test scenarios to be used in a test campaign,
  • Define how many test vectors each of these scenarios should generate,
  • Execute the code stimulated by all these test vectors,
  • At the end, compile all the results and consolidate the requirements coverage for all the scenarios?
Check this 3mn video:
