Program
BIOVIA Pipeline Pilot
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the release of BIOVIA Pipeline Pilot 2022 HF3 which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA Pipeline Pilot includes the following enhancement.
Description | User Story |
The expat XML parser library is updated to the latest available version (2.4.7). | PPC-10636 |
Fixed Defects
This release of BIOVIA Pipeline Pilot includes the following fixed defect.
Severity | Description | Defect |
Minor | Fixed an issue where files written to S3 had a WebDav path as content instead of the expected content. | PPP-47797 |
BIOVIA Pipeline Pilot 2022 HF1 included fixes for the following defects, and BIOVIA Pipeline Pilot 2022 HF3 also ensures these fixes are made, in the case where HF1 was not previously installed.
Minor | Fixed an issue where the Admin Portal Setup/Server Configuration and Security/Security Configuration pages would not notify the administrator when settings that require a restart of the Apache and Tomcat PLP services are changed. | PPP-47526 |
Minor | Fixed the Security/Authentication page to work correctly when logged into the Admin Portal as an external account (such as a Windows Domain or Linux Local user). | PPP-47618 |
Major | Fixed an issue where setting the parameter "Use Absolute Urls" to true would create invalid JavaScript within HTML reports written to locations outside the job folder if the report included interactive charts. "Use Absolute Urls" is a new parameter for Pipeline Pilot 2022 that restores v2021 and earlier behavior of writing absolute HTTP URLs within reports. The default behavior of reports in v2022 is now to use relative server paths for internal HTML links (see the Release Notes for v2022), but there are use cases where the absolute paths must still be used. | PPP-47592 |
Minor | Browsers with existing valid session cookies from prior versions of Pipeline Pilot (2021.2 and earlier) would not be able to authenticate to a 2022.1 server. The server home page and web port portals would become inoperative and the login page would not work correctly. The server error logs would indicate that the session had expired. This would most often occur immediately following an upgrade of an existing Pipeline Pilot server. Such valid sessions are now converted to the new format. | PPC-10539 |
Minor | It was observed that large numbers of API HMAC /auth/serverstatus log messages would appear in the scitegicerror_apache.log when Professional Clients would connect to the server from hosts with large latency to the server, such as from a separate continent. The messages were innocuous and generally did not affect the client's behavior. The messages will now only appear if multiple API HMAC failures occur on the server in rapid succession. | PPC-10536 |
Major | Guidance and installer to ensure a Windows server has the latest VS2017 redistributable required by the Qt library used in the chemistry collection. | PPD-2881 |
Resolution
BIOVIA Pipeline Pilot 2022 HF3 was released in April 2022 and is available for download at https://software.3ds.comunder BIOVIA products and can be found under:
Product line: Lab, Scientific and Content Solutions
Release: BIOVIA 2022
Level: BIOVIA 2022 Golden
Fixes for this level: BIOVIA 2022 Golden HF3
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
